Siebel Order Management Guide Addendum for Communications > Using Network Ordering > Process of Ordering New Networks > Converting a Completed Network Order to AssetsAs components of the network order are installed, convert the line items representing these components to assets so that you can track these assets for service and change orders. For more information about converting orders to assets, see the topic about the workflow that applies an order to the service profile in Siebel Order Management Guide. NOTE: Before configuration, you can use the Auto Asset button to convert line items to assets. However, during configuration, the Auto Asset button is usually removed, and the process is automated. If the Auto Asset button is available, then use the following procedure. This task is a step in Process of Ordering New Networks. |
| Siebel Order Management Guide Addendum for Communications | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
