Siebel Order Management Guide Addendum for Communications > Setting Up Network Ordering >
Setting Up Premises
This optional task automatically populates fields when the salesperson captures the customer network locations or creates the customer network. When creating a network node, a salesperson enters the location service address, and the Siebel application populates the LATA, CLLI, and other fields based on the information that you enter when you set up premises.
NOTE:  The user can also enter this data in the Address Profile view of the Accounts screen.
To set up premises
  1. Navigation to the Administration - Data screen.
  2. On the link bar, click Premises.
  3. In the All Premises list, add a new record.
  4. In the More Info form, click the More button.
  5. Fill out the necessary information in the record and More Info form. Some fields are described in the following table.
    Field
    Description
    Prefix
    Enter the area code and first three digits of the telephone number for this location.
    CLLI
    Enter the Common Language Location Identifier (CLLI) code. This standard is used primarily in the United States.
    LATA
    Enter the Local Access and Transport Area (LATA). This term is used in the United States and defines a geographic area that a local telephone carrier covers.
    Rate Center
    Enter the rate center. A rate center is a geographic area that contains one or more NPA NXX codes. A rate center helps determine the cost of traffic to and from two points.
    Local Operating Company
    Select the local telecommunications service provider. The dialog box displays all accounts for which Wireline Operating Company is in the Account Type field.
Siebel Order Management Guide Addendum for Communications Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
