Siebel Order Management Guide Addendum for Communications > Setting Up Network Ordering > Enabling and Disabling Cross-Network ValidationYou enable and disable cross-network validation by setting the ValidateOtherNetwork user property. By default, it is enabled. NOTE: You might also have to install and configure a product patch to enable cross-network validation. For more information, see the documentation for the patch. Enabling Cross-Network ValidationUse the following procedure to enable cross-network validation. To enable cross-network validation
For more information about changing user property values, see Using Siebel Tools. Disabling Cross-Network ValidationUse the following procedure to disable cross-network validation. To disable cross-network validation
For more information about changing user property values, see Using Siebel Tools. |
| Siebel Order Management Guide Addendum for Communications | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
