Siebel Order Management Guide Addendum for Communications > Partner Asset-Based Ordering > Order Management with Standard Partner Commerce > Customizing an Item (Standard Partner Commerce)Standard Partner Commerce users customize items by selecting item components and attributes in a configuration session. To start a configuration session, the user clicks Customize. When the user exits the configuration session, the configuration is transferred to the shopping cart. NOTE: Users can customize only customizable or complex products. If the quantity of a configurable item is greater than one, then the configuration is applied to each of the configurable items. For example, a user adds a configurable residential phone service package to the shopping cart, specifies 4 in the Qty field, and clicks Customize. When the user exits the configuration session, the configuration is applied to all 4 of the residential phone service packages. You must have a Configurator license to configure customizable products.
| Siebel Order Management Guide Addendum for Communications | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
