Siebel Order Management Guide Addendum for Communications > Creating Communications Promotion Groups > Process of Setting Up Promotion Groups (Administrators) >
Defining Asset Membership Cardinality Rules
Asset membership cardinality rules are cardinality rules that apply to the association of assets with promotion group memberships. These rules apply to the cardinality of the assets associated with memberships but not to the cardinality of the memberships themselves. Membership cardinality rules apply to all assets associated with a promotion group membership and are defined at the membership definition level. Examples of asset membership cardinality rules include the following:
  • An asset can be associated with the Sponsor Mobile membership of one Family Connect promotion group and with the Invitee Mobile membership of up to four Family Connect promotion groups.
  • An asset cannot exist unless it is associated with the Invitee Mobile membership of a Family Connect promotion group.
To define asset membership cardinality rules, follow this procedure.
This task is a step in Process of Setting Up Promotion Groups (Administrators).
  1. Navigate to the Administration - Product screen, then the Product Definitions view.
  2. In the Products list, query for records with any Type field value except Promotion Group Membership.
  3. Select a membership product for which you are specifying cardinality rules, and click the link in the Product field.
  4. Click the Eligibility and Compatibility Rules view tab.
  5. In the link bar of the Eligibility and Compatibility Rules view, click the Asset Membership Cardinality link.
  6. In the Products form, select the Check Asset Member Compatibility check box.
    Selecting this field enables your Siebel application to assess asset membership cardinality rules for this product.
  7. For each cardinality rule you want to create, in the Asset Membership Cardinality list, add a new record, and complete the necessary fields.
    Some fields are described in the following table.
    Field
    Comments
    Promotion Group
    Use this field to select a promotion group to which to apply this rule.
    Membership
    Use this field to select a membership definition to which to apply this rule. The options include the membership definitions that are associated with the selected promotion group.
    Minimum
    Use this field to specify the minimum number of times an instance (asset) of the current product can be associated with the selected membership of an instance of the selected promotion group.
    Maximum
    Use this field to specify the maximum number of times an instance (asset) of the current product can be associated with the selected membership of an instance of the selected promotion group.
  8. Click Clear Cache to clear the cache.
Siebel Order Management Guide Addendum for Communications Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
