Siebel Order Management Guide Addendum for Communications > Creating Communications Promotion Groups > Process of Setting Up Promotion Groups (Administrators) > Releasing a Promotion Group DefinitionWhen you created a new promotion group definition record, a version of it named Work Space was automatically created and the Locked check box was automatically selected for the version record. After you finish setting up the promotion group definition, you must release this version and refresh the cache to make the promotion group definition available to users. Promotion group versions affect only the Start Date, End Date, and Active fields of the promotion group. Every other aspect of promotion groups is uniform for all active versions. You must refresh the cache after making any changes to the promotion group definition. This task is a step in Process of Setting Up Promotion Groups (Administrators). To release a promotion group definition
| Siebel Order Management Guide Addendum for Communications | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
