Siebel Order Management Guide Addendum for Communications > Creating Communications Promotion Groups > Process of Creating Promotion Groups > Adding Memberships to a Promotion GroupWhen you generate a promotion group, your Siebel application adds the default memberships that are defined by the membership definitions associated with the promotion group definition. You can also add other memberships to the promotion group. This task is a step in Process of Creating Promotion Groups. To add a membership to a promotion group
| Siebel Order Management Guide Addendum for Communications | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
