Siebel Order Management Guide Addendum for Communications > Creating Communications Promotion Groups > Process of Setting Up Promotion Groups (Administrators) >
Adding Reward Definitions to a Promotion Group Definition
You can add the reward definitions that are part of the selected promotion group definition, either as components (individual products) or as aggregates (product lines or product classes). To add reward definitions to the selected promotion group definition, follow this procedure.
This task is a step in Process of Setting Up Promotion Groups (Administrators).
To add reward definitions to a promotion group definition
  1. Navigate to the Administration - Product screen, then the Promotion Groups view.
  2. In the Promotion Group Definitions list, select the promotion group definition for which you are specifying rewards.
  3. Click the Products view tab.
  4. In the link bar of the Products view, click the Group Rewards link.
  5. Add a new record to the Group Rewards list, and complete the necessary fields.
    Some fields are described in the following table.
    Field
    Comments
    Product Name
    Select a component product as a reward for the current promotion group definition.
    Class
    Select an aggregate product as a reward for the current promotion group definition.
    Product Line
    Min
    This field defines the minimum reward cardinality. Enter the minimum number of instances of the selected promotion group in which an asset of the product or aggregate reward can be associated with this reward.
    Max
    This field defines the maximum reward cardinality. Enter the maximum number of instances of the selected promotion group in which an asset of the product or aggregate reward can be associated with this reward.
    Default
    If you want to display a default quantity, then enter the default quantity of this reward that is associated with the promotion group definition. If the customer selects this promotion group in a quote or order, then the default quantity of all rewards in the promotion group is added as line items to the quote or order.
    This field is optional. If you do not enter a value, then your Siebel application uses the value entered in the Min field as the default value.
    Customizable
    Read only. If this check box is selected, then the reward is a customizable product.
    NOTE:  The Default Product list below the Group Rewards list displays the default product for each reward that is defined as an aggregate product in the Class and Product Line fields.
  6. To enter translations of descriptions of the membership definition to be shown in catalogs that are not in the default language, add a record to the Translations list for each language your company supports, and complete the necessary fields.
    For information about the fields in the Translations list, see Adding Membership Definitions to a Promotion Group Definition.
Siebel Order Management Guide Addendum for Communications Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
