Siebel Order Management Guide Addendum for Financial Services > Managing Financial Service Applications > Using Siebel Configurator to Customize Financial ProductsSiebel Configurator is used to customize financial products in a quote or order. You can use the Customize button to start a Configurator session. The Customize button is enabled when the customizable product is selected in the Quote or Order Line Items view. Customizing might involve adding components to one or more products within the quote. You can also use the Modify or Revise buttons in the Financial Applications view to start a Configurator session. You can use Siebel Configurator to:
This task is a step in Process of Creating a Financial Services Application. |
| Siebel Order Management Guide Addendum for Financial Services | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
