| Siebel CRM Partner Relationship Management Administration Guide Siebel Innovation Pack 2015 E24800-01 |
![]() Previous |
![]() Next |
View PDF |
To use the CHAMP Planning Module in Siebel PRM, you perform the following tasks:
A detailed diagram of the steps the brand owner performs in the CHAMP Planning Module of Siebel PRM is shown in Figure 7-1, "Using the CHAMP Planning Module of Siebel PRM (Brand Owner's Viewpoint)".
A detailed diagram of the steps the partner performs in the CHAMP Planning Module of Siebel PRM is shown in Figure 7-2, "Using the CHAMP Planning Module of Siebel PRM (Partner's Viewpoint)".
This task is a step in "Process of Using the Siebel PRM CHAMP Planning Module".
You must create CHAMP metrics before you create any CHAMP plans.
CHAMP metrics let you categorize CHAMP objectives in ways that let you measure them. For example, if you are going to develop a series of CHAMP plans with different partners to increase sales of a product, you could create a metric named Sales Revenue. Then, when you evaluate partner performance, you can search on the metric field to list the objectives with Sales Revenue as the metric, so you can compare the target and actual performance of your partners.
In CHAMP planning, performance is measured using the Target and Actual value fields of each objective. The metric defines and categorizes objectives, so you can measure and compare the performance of different partners.
You must create all the appropriate metrics before creating any CHAMP plans. Analyze your CHAMP planning program and decide how you want to use metrics to measure and categorize objectives. When you create a specific CHAMP plan, the metrics that you have created are available in the picklist of the Metrics field of the plan's objectives.
If you have an ongoing CHAMP planning program, view existing CHAMP metrics before adding any new metrics.
To view CHAMP metrics
Before you add new metrics, analyze your CHAMP planning program and decide what metrics you need to measure the performance of your CHAMP participating partners.
To add a new CHAMP metric
Navigate to the Administration - Data screen, then the List of Values view.
In the List of Values list, add a new record.
The Find List of Values form appears.
In the Type field, enter CHAMP_METRIC_CD.
In the Order field, enter the order in which this metric is to appear on the list of values in the picklist for the Metric field of Objective records.
In the Display Value field, enter the name for this metric that is to appear in the list for the Metric field of Objective records.
Click Language Name, and select the language for this record.
Other fields are optional and are not generally used in CHAMP planning. Complete the other fields only if you have a special reason to do so.
This metric is added to the Metrics list.
After you have created the appropriate CHAMP metrics, you can begin the CHAMP planning.
The first step in CHAMP planning is to create initiatives to outline your high-level partnership strategies.
A partnership initiative is a large-scale or general business strategy that involves working with partners. For example, if a computer manufacturer wants to work with its partners to penetrate the untapped market segment of financial services, it might create an initiative named Foray into Financial Services. It might use existing partners, such as value-added resellers, to work on this initiative or form new partnerships with partner companies that have experience in this industry.
As part of creating an initiative, you specify which partners participate in it.
To create an initiative, you go through the following process:
Add an initiative
Add partners as participants in the initiative
To create initiatives, you must first add an initiative.
Use the following procedure to add an initiative.
To add an initiative
Navigate to the CHAMP Planning screen.
The Initiatives view is displayed by default.
In the Partnership Initiatives list, add a new record.
Enter the information in the following table in the fields of the new record and the fields of the More Info form.
| Field | Description |
| Name | Enter a name for the initiative. |
| Description | Enter a description of the initiative for your own use. |
| Period | Select the period for which this initiative is valid. |
| Start Date | The start date of the selected period is entered automatically, based on your selection in the Period field. This is a read-only field. |
| End Date | The end date of the selected period is entered automatically, based on your selection in the Period field. This is a read-only field. |
| Target Market | Select the market segments toward which this initiative is targeted. |
| Target Amount | Enter the target amount of money you expect this initiative to generate. |
| Target Quantity | Enter the target quantity you expect the initiative to achieve. For example, if the goal of the initiative is to get new customer accounts, enter the number of new accounts you hope to get. |
| Actual Amount | After the period of the initiative has ended, you enter the actual amount of money this initiative generated. |
| Actual Quantity | After the period of the initiative has ended, you enter the actual quantity this initiative achieved. |
| Active | This read-only field indicates whether the initiative is still active. It is automatically set to True on the start date and set to False after the end date. |
Participants in an initiative are partner companies that are best positioned to work on the initiative. You might also form new partnerships with companies that are especially qualified to work on the initiative.
You must add these partners as participants in the initiative.
To add a partner company as a participant in an initiative
In the Partnership Initiatives list, drill down on the name of the initiative to which you want to add partners.
Click the Initiative Participants view tab.
The Initiative Participants list appears.
In the Initiative Participants list, add a new record.
The Add Partner dialog box appears.
Choose one or more partners and click OK.
The partners are added to the Participating Partners list.
Partner plans allow brand owner companies to work with their partners to set up joint business plans that contribute to initiatives. A partner plan is specific to one partner company. For example, a partner plan could have a specific partner company generate $1M in revenues by selling a 300GHz server to the financial services customers in the northeastern United States. This plan goal could eventually contribute to a larger initiative to generate $500M from the sales of the new 300GHz server. These plans include specific objectives for each partner, so that you can measure each partner's performance on this initiative.
Initiatives are general company strategies, so they are visible only to your company. Plans are strategies for working with specific partner companies, and so they are visible to your company and to the partner companies that are involved.
To create and use a partner plan, you go through the following process:
Create a new plan, which involves the following steps:
Add a plan and its highlights.
Add objectives for the plan.
Associate opportunities with each revenue objective.
Add an Action Plan for each objective with resources for each Action Plan item.
Approve the plan internally and publish it to the partner.
Approve the plan jointly with the partner.
Optionally, add notes to the plan.
From the CHAMP Planning screen, Plans List view a number of different partner plan lists are available. The following table describes each list.
Table 7-1 CHAMP Partner Plan Lists
| List | Description |
My Partner Plans |
This list displays all partner plans owned by the user. |
All Partner Plans |
This list displays all partner plans of the partners in the same organization as the user. |
All Partner Plans Across My Organizations |
This list displays all partner plans of the partners in the same organization and sub-organizations of the user. |
All Partner Plans Across Organizations |
This list displays all the partner plans of the partners in all organizations. |
The first step to create a new plan is to add a new Plan record, with which you associate the information about the plan.
When you add a plan record, you also enter the highlights for the plan, which are an overall view of the goal, value propositions, and critical success factors for the plan.
To add a new plan and its highlights from the CHAMP Planning screen
Navigate to the CHAMP Planning screen, then the Plans List view.
In the My Partner Plans list, add a new record.
Enter the information in the following table in the fields of the new record and of the More Info form.
| Name | Enter a name for the partner plan. |
| Partner | From the list of partner companies, select the name of the partner for which this plan is being created. |
| Period | Select the period for which the plan is valid. For example, the picklist might contain 2008 or Q2 2008. |
| Period Type | This read-only field displays whether the period you selected is a quarter, month, year, and so on. |
| Start Date | This read-only field displays the start date of the period you selected. |
| End Date | This read-only field displays the end date of the period you selected. |
| Status | Select the status of the plan. When you are working on creating the plan, select In Progress. When you submit the plan for internal review, select Pending Review. Later, as the plan is approved by the internal audience, select Internally Approved and when the plan is approved both by the internal and the partner audience, select Jointly Approved. |
| Publish to Partner | This field indicates whether the plan is visible to the partner through the Siebel PRM Web site. When you are creating the plan, select False. Later, after the plan has been internally approved and is ready to be approved by the partner, select True. |
| Active | This read-only field indicates whether the plan is still active. It is automatically set to True on the start date and set to False after the end date. |
| Created Date | The date when the plan record was created is entered automatically. |
| Created By (Created by Name) |
The Login ID of the person who created the plan is entered automatically. |
| Last Updated (Updated Date) |
The date when the plan record was last modified is entered automatically. |
| Last Updated By (Updated By Name) |
The Login ID of the person who last modified the plan is entered automatically. |
Click the plan name to drill down to the Plan Objectives view of the CHAMP Planning screen, which is used for adding objectives to the plan. For more information on adding objectives, see "Adding Objectives to the Plan".
To add other key information about the plan, click the Plan Highlights view tab.
In the Plan Highlights form, enter the information in the following table.
| Plan Goal | Enter the plan's goal, describing the overall purpose of the plan. For example, a plan goal could be Increase market share for the new servers by 20% before the end of fiscal year 2008. |
| Value Proposition to My Company | Enter a description of the plan's value proposition to your company. For example, the value proposition could be Increased market share for my new servers. |
| Value Proposition to Partner | Enter a description of the plan's value proposition to this partner company. For example, the value proposition could be New line of business. |
| Value Proposition to Market | Enter a description of the plan's value to the market. For example, the value proposition could be Availability of better and high-performance server products. |
| Critical Success Factors | Enter a description of the critical success factors of the plan. For example, some of the critical success factors could be Timely training and certification of the partner in the new server products and Timely execution of focused marketing campaigns. |
Objectives establish specific goals for the partner plan, which are used later to measure the partner's success in implementing the plan.
When you create an objective, you enter a target for that objective. After the plan has been completed, the actual performance data can be entered manually or automatically.
An objective is defined using metrics. Metrics allow objectives to be measurable and categorized. Objectives can be revenue or nonrevenue. For example, "Generate $3M in revenues" is a revenue objective while "Train three employees from the partner company" is a nonrevenue objective. To allow measurement of both these types of objectives, Siebel PRM allows you to define quantity and amount metrics as follows:
Quantity. If the objective is a quantity, enter the target quantity when you create the objective and enter the actual quantity after the objective is completed. For example, if your company is trying to sell a new line of printers, the measure could be the number of printers the partner has sold.
Amount. If the objective is an amount, enter the target amount when you create the objective and enter the actual amount after the objective is completed. For example, if your company is trying to achieve $3M in sales by selling a new line of printers, you could measure your partner on the amount of sales revenue generated by selling the new line of printers.
To enter plan objectives
Select the appropriate partner plan list and drill down on the name of the plan to which you want to add objectives.
Click the Plan Objectives view tab.
In the Plan Objectives list, add a new record.
Enter information in the following table about the objective in the new record and in the More Info form.
| Name | Enter a name for the objective. |
| Strategy | Enter a general summary of your strategy for how this objective is to be achieved. |
| Metric | Select the metric that used to measure the objective. |
| Initiative | Drill down on the name of the initiative to which this objective is linked. |
| Partner Accountable | Select this flag if the partner company is accountable for meeting this objective. (If both your company and the partner company are accountable, select both the Internally Accountable and the Partner Accountable flags.) |
| Internally Accountable | Select this flag if your company is accountable for meeting this objective. (If both your company and the partner company are accountable, select both the Internally Accountable and the Partner Accountable flags.) |
| Product | Optionally, select the product that the partner must sell, be trained on, or work with, as a part of the objective. |
| Training Course | Optionally, select the training course that must be completed as part of the objective. |
| Target Quantity | Enter the target value for the metric associated with this objective. |
| Target Amount | Enter the target value for the metric associated with this objective. |
| Condition Clause | Enter a brief description of the condition that must be satisfied. |
| Target Industry | Optionally, select industries that are targeted as a part of the objective. |
| Target Market | Optionally, select the market that is targeted as a part of this objective. |
| Fund | Optionally, select the market development funds used for the objective. |
| Actual Quantity | At the end of the plan period, enter the actual value for the metric. You can do this manually, or if the product has been configured with the appropriate workflows or business services, it can be done automatically. |
| Actual Amount | At the end of the plan period, enter the actual value for the metric. You can do this manually, or if the product has been configured with the appropriate workflows or business services, it can be done automatically. |
| Condition Met | When the plan has been completed, if the metric has a condition, select this flag if the condition clause was satisfied, or leave it unselected if the condition clause was not satisfied. |
| Shared | This flag defaults to True to indicate that this objective is shared with the partner and is a CHAMP objective. If you deselect this flag so the objective is not visible to the partner, then you must select the Internally Accountable flag and deselect the Partner Accountable flag, to indicate that your company is solely accountable for this objective. |
Continue to add new records to the Objectives list until you have entered the objectives for this plan.
From the CHAMP Planning screen, Objectives List view a number of different objectives lists are available. The following table describes each list.
Table 7-2 CHAMP Objectives List
My Plan Objectives |
This list displays all plan objectives owned by the user. |
All Plan Objectives |
This list displays all plan objectives of the partners in the same organization as the user. |
All Plan Objectives Across My Organizations |
This list displays all plan objectives of the partners in the same organization and sub-organizations of the user. |
All Plan Objectives Across Organizations |
This list displays all plan objectives of the partners in all organizations. |
If an objective is a revenue objective, that is, if it has a metric such as sales revenue or some other form of direct revenue, you can associate it with an opportunity or opportunities. This feature lets you develop a road map of how the revenue target will be achieved in terms of the available opportunities.
You can associate one or more opportunities with each revenue objective.
To associate an opportunity plan with a revenue objective
Navigate to the CHAMP Planning screen, then the Objectives List view.
Select the appropriate objectives list and drill down on the objective with which you want to associate an opportunity.
Click the Opportunity Plan view tab.
In the Opportunity Plan list, add a new record.
Choose one or more opportunities and click OK.
You develop a specific action plan for every objective. An action plan is a list of activities that your company and the partner company will perform to achieve the objective.
When you create the action plan, you give each of its activities a planned start date and completion date. As you execute the plan, you enter the actual start and completion dates for each activity. If an activity is created by a partner or assigned to a partner, your partner must record its progress by using the Siebel PRM Portal to enter the begin and completion dates, and you can check its progress using the Siebel PRM Manager.
You also specify the resources that you have available for each activity in the action plan.
To add an action plan and resources for an objective
Drill down on the desired objective.
In the Action Plan list, add a new record, and enter information about the first activity of the action plan, as described in the following table.
| Name | Enter a name for the activity. |
| Description | Enter a description of the activity. |
| Type | Enter the type of activity, such as customer visit. |
| Assigned To | The person who created this activity is automatically entered in this field. |
| Status | Choose a value to indicate the progress of the activity. |
| Due | Enter the date on which this activity is due. |
| Priority | Select a value that indicates the importance or urgency of this activity. |
| Planned Start | Enter the planned start date of the activity. |
| Planned Completion | Enter the planned completion date of the activity. |
| Actual Start | When a user begins working on this activity, the user enters the date in this field. |
| Actual Completion | When a user completes this activity, the user enters the date in this field. |
| % Complete | When users work on the plan, they can indicate how close this activity is to being completed. |
| Account | Select the account that is related to this activity. |
| Programs/ Other Comments |
Optionally, enter materials, equipment, any program participation information, or other miscellaneous comments. |
| Last Name | Optionally, enter the last name of the contact related to this activity. |
| First Name | Optionally, enter the first name of the contact related to this activity. |
| Associated Cost | Optionally, enter the amount of money needed for this activity. |
| Campaign | Optionally, select a campaign that is associated with this activity. |
| Fund Request | Optionally, select a fund request associated with this activity. |
| Site | The location of the selected account. |
In the Resources list, enter the resources from the following table that you have available for this activity in the Resources form.
| Last Name | Enter the last name of the person who works on this activity. |
| First Name | Enter the first name of the person who works on this activity. |
| Job Title | Enter the job title of the person who works on this activity. |
| External Organization | Enter the organization of the person who works on this activity, if it is not in your own organization. |
| Enter the email address of the person who works on this activity. | |
| Work Phone # | Enter the work phone number of the person who works on this activity. |
| Home Phone # | Enter the home phone number of the person who works on this activity. |
| Alias | Optionally, enter an alias for the person who works on this activity. |
You can add notes when you are creating a plan or when working on the plan after it has been approved. Notes let you enter free text comments about the plan. There are two types of notes:
Private Notes. These are notes that can be seen only by the person who created the note. These notes are used to record miscellaneous information about the plan for your own use.
Shared Notes. These are notes that can be seen by everyone in your company who has access to that view and record. These notes are used to share miscellaneous information about the plan.
To add notes to a plan
Select the appropriate plan list and drill down on the name of the plan to which you want to add a note.
Click the Plan Notes view tab.
Add a new record to either the Shared Notes or the Private Notes list.
Enter the note in the new record's fields, as described in the following table.
| Created | The date when the note was created is entered automatically. |
| Note Type | Enter the type of the note. For example, it might be "Directions" or "Reference." |
| Note | Enter the text of the note. |
After a partner plan is created, discuss and approve it internally. You can then publish the plan to the partner company, and the partner can view it through the Siebel PRM Portal.
To publish a plan to a partner company
In the record for the partner plan that you want to publish, select the Publish to Partner check box.
When this check box is selected, the partner can see the plan on the Siebel PRM Portal.
After the plan is published, the partner company can access the plan through the Siebel PRM Portal and can change the action plan by adding new activities, deleting activities, changing the start dates of activities, and so on.
If the partner company has no objections to the plan, it can immediately approve the plan by using the Siebel PRM Portal to select Jointly Approved in the Status field.
If the partner company has made changes to the plan, your company and the partner company must review the plan jointly, to make changes that are necessary to make it acceptable to both. Once both companies have approved the plan, you can change its status to Jointly Approved.
To change a plan's status to Jointly Approved using the Siebel PRM Manager
In the Status field of the plan, select Jointly Approved.
Use the following procedure to change a plan's status to Jointly Approved using the Siebel PRM Portal.
To change a plan's status to Jointly Approved using the Siebel PRM Portal
In the Siebel PRM Portal, the partner navigates to the CHAMP Planning screen.
In the Partner Plans list, in the Status field of the appropriate plan, the partner selects Jointly Approved.
After the plan has been jointly approved, your company and the partner company can execute the plan.
You can analyze and evaluate the performance of your partner companies while the plan is being executed and after the plan is completed.
One of the powerful aspects of CHAMP planning is that it allows you to analyze and measure partner performance against the targets set in the partner plans.
While the plan is being executed, you can view the plan periodically to review the partner company's performance. The partner company can also check its performance during the plan period. If the actual values are not on track to reach the target values, the problem can be corrected.
After the plan is completed, you review the partner's performance thoroughly, taking action to correct problems and rewarding good performance.
You evaluate the partner's performance by comparing the values in the Actual Quantity and the Actual Amount fields with the target values that you entered when you created the objective as part of the partner plan.
After the end date for the plan, you can manually enter the actual values. You can also automate the entry of actual values using workflow rules or business services. For example, a workflow could be written to populate to the actual values based on transactional data such as opportunities, service requests, orders, and so on.
For example, if a partner has a revenue objective of $20 million during the plan period of fiscal year 2005, then Siebel Business Process Designer can be configured so that, at the end of the plan period, it adds the revenues associated with all the opportunities this partner closed during the year and enters this computed revenue in the Actual Value field for this objective.
You can also evaluate performance by comparing the performance of different partners. For more information about Siebel Business Process Designer, see Siebel Business Process Framework: Workflow Guide.
To evaluate partner performance across multiple partners
Navigate to the CHAMP Planning screen, then the Performance Across Partners view.
As shown in the following table, choose values in the fields of the Plan Objectives list to view the performance of your partners. When a combination of criteria is selected, you see objectives that meet these criteria.
| Metric | Allows you to choose objectives for a particular metric or the metrics for which there are associated objectives.
The Performance On a Metric chart and the Performance Over Time chart are valid only if you choose a metric here. |
| Partner | Allows you to choose objectives for a particular partner or the partners in your portfolio for which you have a partner plan. |
| Plan | Allows you to choose objectives for a particular partner plan or all partner plans. |
| Plan Period | Allows you to choose objectives for a particular plan period or all plan periods. |
Use the Link bar in the chart to toggle between the following charts:
Performance Over Time, which displays the performance of your partners across different plan periods for both quantity and amount metrics.
Performance On a Metric, which displays the performance of your partners over different metrics for both quantity and amount metrics.
Use the following procedure to evaluate partner performance for an individual partner.
To evaluate partner performance for an individual partner
Navigate to the Partners screen, then the Partner List, and All Partners Across Organizations view.
In the Partners list, drill down on the name of the partner you want to evaluate.
Click the Partner Performance view tab.
As described in the following table, choose values in the fields of the Objectives list to view your partner's performance. When a combination of criteria is selected, you see objectives that meet these criteria.
The Performance On a Metric and the Performance Over Time charts are valid only if you choose a metric here. |
To display charts evaluating Partner Performance
Navigate to the Partners screen, then the Partner List view.
In the Partners list, drill down on the name of the partner whose performance you want to evaluate.
In the link bar, click Performance Over Time.
In the Performance Over Time (Amount) or the Performance Over Time (Quantity) views, use the lists to choose the time periods for which you want to display a chart and the type of chart you want to display.
Charts are displayed showing the partner's performance during the time period as measured by an amount metric or by a quantity metric.
Navigate to the Performance On a Metric chart, and in the Plan Objectives list, click the lists to choose the metric, the partner, the plan, and the plan period for which you want to measure performance.
In the Performance On a Metric (Amount) or the Performance On a Metric (Quantity) views, use the lists to choose the chart you want to display.
Charts are displayed showing the partner's performance against this metric for an amount metric or for a quantity metric.
After the CHAMP plan has been completed, you conduct a thorough review of the partner company's performance. You can see how it performed by comparing the actual values with the target values. You might also want to compare that partner with other partners on similar metrics, to see which partners are performing the best.
You can take the following actions based on your evaluation:
For nonperforming partners, you can make changes in future action plan items to make them more feasible, you can recommend corrective actions to the partner, or you can take some other corrective action, such as giving the partner more training.
Performing partners can be rewarded. For example, you could increase their market development funds (MDFs), give them more opportunities, give them awards or recognize them for a job well done, or reward them in some other way.
After you have finished working on an initiative and you have evaluated its success, you can start a new planning cycle by creating new initiatives. Your reviews of the partners' performance and of the initiative's performance help you plan the next initiative more successfully.
