Siebel Personalization Administration Guide > Targeting Content by Using Expressions > Hyperlinking Salutation Messages > Hyperlinking to Siebel Employee Relationship Management ViewsYou can also use this command to hyperlink to Siebel Employee Relationship Management views. <A href=JavaScript:SWEPersonalizationGotoview('My+View <A href=JavaScript:SWEPersonalizationGotoview('My+View Make sure there are no spaces: The ampersand for the first myExtra parameter is optional. You can also use the following syntax: <A href=JavaScript:SWEPersonalizationGotoview('My+View There is no dup argument checking mechanism. If your myExtra parameters contain an argument that SWE has already generated, undesired behavior might occur. |
| Siebel Personalization Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
