Siebel Pricing Administration Guide > Creating Discount Matrices > Process of Creating a Discount Matrix >
Modifying the Pricing Procedure - Calculate Net Price Workflow to Include a Discount Matrix
When you use a discount matrix, you must added an additional step to the workflow Pricing Procedure - Calculate Net Price to apply the discount matrix to the pricing. For more information about this workflow, see Pricing Procedure - Calculate Net Price Workflow. To modifying the Pricing Procedure - Calculate Net Price workflow to include a discount matrix
- In Siebel Tools, select the Pricing Procedure - Calculate Net Price workflow process. Revise and edit this workflow process.
- After the Tiered Volume Discount Upsell step, add a new business service step that queries the appropriate discount matrix business component for any discounts associated with each account type.
- Define the step as shown in the following table.
Account Type Adjustments |
Business Service |
Row Set Transformation Toolkit |
Simple Look-Up Transform |
- Define the input arguments as shown in the following table.
Context |
Process Property |
Context |
Row Set |
Process Property |
Row Set |
Business Object |
Literal |
Adjustment Group |
Business Component |
Literal |
Product-Based Adjustment |
Process Condition |
Literal |
{Row.Product Id} IS NOT NULL AND {Context.Account Type} IS NOT NULL |
Search Specification |
Literal |
[Adjustment Group Name] = 'Account Type Discount' AND [Account Type] = {Context.Account Type} |
On First Match 1 |
Literal |
{Row.Net Price} = AdjustPrice({Row.Net Price}, {Row.Currency Code}, LookupName("PRICER_CALCULATION_SIMPLE_TYPE", {Match.Adjustment Type}), {Match.Adjustment Amount}, {Match.Currency Code}, {Row.Exchange Date}) |
On First Match 2 |
Literal |
{Row}.{Net Price Waterfall} += New("Waterfall", [Adjustment Amount] = {Match.Adjustment Amount}, [Adjustment Type] = {Match.Adjustment Type}, [Price] = {Row.Net Price}, [Currency Code] = {Row.Currency Code}, [Text] = LookUpMessage ("Pricer - Account Type Discount",[Account Type] = {Match.Account Type} ,[Discount Matrix] = {Match.Adjustment Group Name})) |
- Define the output arguments as shown in the following table.
Context |
Context |
Output Argument |
Row Set |
Row Set |
Output Argument |
- Deploy the updated workflow process.
