Siebel Pricing Administration Guide > Creating Discount Matrices > About Configuring Discount Matrices > Adding New Dimensions to Existing Discount Matrix TypesNOTE: This topic includes instructions that assume you are familiar with Siebel Tools. For more information, see Using Siebel Tools. These instructions also assume that you have made the appropriate data model extensions to the appropriate discount details table. You must use Siebel Tools to add new dimensions to existing discount matrix types. To add new dimensions to existing discount matrix types using Siebel Tools
If the new field was added as a criteria dimension, then it now appears as a selection in the discount criteria pick applet for the appropriate discount matrix type. If the new field was added as a calculation or result dimension, then it now appears in the Discount Details applet when the user drills down on a discount matrix with the appropriate discount matrix type. |
| Siebel Pricing Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
