Siebel Pricing Administration Guide > Setting Up Pricing for Products with Components > Viewing and Changing the Reference Price >
Exposing the Starting Price At in the Product Catalog
Use the following enhancements to expose the Starting Price At field in the product catalog UI.
  1. Workflow: In the Basic Pricing Procedure workflow and the Dynamic Pricing Procedure workflow, add the following input argument to the Get List Price step.
    Input Argument
    Value
    On First Match 15
    {Row. Reference Price} = {Match. Reference Price}
    Then, activate the workflow after the change. For more information about using these workflows, see Pricing Procedures and Workflow References.
  2. Variable Map or Variable Source: In Product Pricing Variable Map - Row Set, and Product Pricing Variable Map - Row Set-Basic, use the following variable definition.
    Variable Name
    In/Out
    Type
    On Null
    Reference Price
    Out
    Currency
    Ignore
    With the new definition, use the following variable sources:
    Mode
    Path
    Source Type
    Any
    $Current/Product/Reference Price
    Instance
    Favorite
    $Current/Favorite/Reference Price
    Instance
    For more information about using variable maps, see Siebel Order Management Infrastructure Guide.
  3. Business Components: Modify the following business components (buscomps).
    Business Component
    User Property
    Change This Value
    Quote Catalog Internal Product by Price List Option
    PSP: Price Fields
    To: List Price, Net Price, Reference Price
    Quote Catalog Internal Product by Price List Optional 2
    PSP:Price Fields
    Quote Catalog Internal Product by Price List Optional - PSS
    PSP:Price Fields
    For more information about business components, see Siebel Order Management Infrastructure Guide.
  4. Applets: Update the following applets:
    Applet
    Change
    Quote Catalog Product Form
    Change field to Reference Price for control PriceStartingAt
    Quote Catalog Product List - Add to Cart
    Change field to Reference Price for list column Price Starting At
    Sales Order Catalog Product List - Add to Cart
    Service Order Catalog Product List - Add to Cart
    Quote Catalog Product List - MultiSelect Checkbox
    Change field to Reference Price for list column Reference Price
    Sales Order Catalog Product List - MultiSelect Checkbox
    Service Order Catalog Product List - MultiSelect Checkbox
    For more information about working with applets, see Using Siebel Tools.
  5. Integration Objects: Update the following objects:
    1. Integration Object: ISS Quote
      • Integration Component: Internal Product PSP Integration
      • Add Integration Component Field:
        Data Type: DTYPE_CURRENCY
        External Name: Reference Price
        XML Tag: ReferencePrice
        Integration Component: Quote Catalog PSP Favorite Item
    2. Integration Object: ISS Order
  6. Business Components (Buscomp): Update these buscomps with the following information.
    Business Component
    Change
    Add a calculated field Reference Price with no Calculated Value and type of DTYPE_CURRENCY.
Siebel Pricing Administration Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
