Siebel Pricing Administration Guide > Creating Attribute Adjustments >
Example of Creating an Attribute Adjustment with Nonproduct Attributes
This topic gives one example of how to create attribute-based pricing with nonproduct attributes. You may use this feature differently, depending on your business model.
In this example, adjustments are applied to the price of automobiles based on three attributes in three different business components:
  • Transmission. This is a product attribute that has the possible values Automatic and Manual.
  • Account Type. This is a header field that has the possible values Customer, Commercial, and Partner.
  • Quantity. This is a line item field that can have any numeric value.
This example creates three possible adjustments based on these attributes:
  • All vans (a product) ordered for a commercial account with manual transmission and a quantity greater than 20 will be priced at $18,000 (price override).
  • All vans ordered for a customer account with manual transmission and a quantity greater than 15 will be marked up by 10% (% Markup).
  • All vans ordered for a partner account with automatic transmission and a quantity greater than 10 will be discounted by 10% (% Discount).
All these discounts apply to the price list named Americas Price List.
This example assumes that you have already created the class Horizon Autos, the product Van, and the price list Americas Price List. For information about creating classes and products, see Siebel Product Administration Guide. For information about creating price lists, see Creating and Assigning Price Lists.
Modifying the Variable Map
First, you must modify the variable map Default Pricing Variable Map - Context, so Account Type is defined as a variable in this map. Do this only if Account Type is not already defined as a variable in the map.
To modify the variable map
  1. Navigate to the Administration - Order Management screen, then Variable Maps view.
  2. Select and lock the variable map Default Pricing Variable Map - Context.
  3. In the Versions list, click Workspace.
    Details of the new version of the variable map appear.
  4. In the Variable Definitions list, add a new record and complete the necessary fields.
    Some fields are shown in the following table:
Field
Value
Variable Name
Account Type
In/Out
In
Type
Text
On Null
Ignore
  1. In the Variable Sources list, specify the source of the new variable, as shown in the following table:
Field
Value
Mode
Any
Path
$Current/Header/Account Type
Source Type
Instance
  1. Restart the client application to make sure that the variable map changes are available.
Creating the Attribute Adjustment Record
The type of the Attribute Adjustment record must be multiple, because the price adjustments depend on more than one attribute. The type must be associated with the class Horizon Autos, which includes these attributes.
To create the attribute adjustment record
  1. Navigate to the Administration - Pricing screen, then Attribute Adjustments view.
  2. In the Attribute Adjustments list, add a new record and complete the necessary fields.
    Some fields are described in the following table:
    Field
    Value
    Name
    Horizon Autos
    Class
    Horizon Autos
    Type
    Multiple Dimension
Specifying Dimensions and Domains
Next, set up the dimensions that you want to use in the attribute adjustments. You must add three condition dimensions for the attributes that are the basis of price adjustments (Transmission, Account Type, and Quantity).
Also, you must add two result dimensions that determine the amount of the price adjustment (Adjustment Amount and Adjustment Type), which are added automatically when you click Create Result Dimensions.
You also enter the domains for each of these dimensions. Select the Bounded check box in the Dimension records to control data entry in the Rules list, so only valid values can be entered in the columns for these dimensions.
To specify the result dimensions and their domains
  1. In the Attribute Adjustments list, click Create Result Dimensions.
  2. Click the Pricing Dimensions view tab.
    Records have already been added to the Dimensions list for the two result dimensions, Adjustment Amount and Adjustment Type.
  3. Add a record to the Dimensions list to represent the Transmission attribute and complete the necessary fields, as described in the following table:
    Field
    Value
    Dimension Type
    Condition
    Name
    Transmission
    Operator
    Variable Map Type
    XA
    Data Type
    Text
    Domain Type
    Attribute
    Bounded
    Y
    Attribute
    Transmission
    Sort Order
    1
    Sort Method
    Ascending
  4. Click Create Domain.
    The two values for this domain (automatic and manual) appear in the Domain list.
  5. Add a record to the Dimensions list to represent the Account Type attribute and complete the necessary fields, as described in the following table:
    Field
    Value
    Dimension Type
    Condition
    Name
    Act Type
    Operator
    Variable Map Type
    Context
    Data Type
    Text
    Domain Type
    Business Component
    Bounded
    Y
    Business Object
    List of Values
    Sort Order
    2
    Sort Method
    Ascending
    Business Component
    List of Values
    Field
    Value
    Search Spec
    [Type] = "ACCOUNT_TYPE"
    NOTE:  In this example, Business Component is used as the domain for setting up the Act Type dimension. However, a better way to define the domain in practice would be to use LOV with the value ACCOUNT_TYPE in the LOV field.
  6. Click Create Domain.
    The values for this domain appear in the Domain list.
  7. Add a record to the Dimensions list to represent the Quantity attribute and complete the necessary fields, as described in the following table:
    Field
    Value
    Dimension Type
    Condition
    Name
    Quantity
    Operator
    Variable Map Type
    Row
    Data Type
    Number
    Domain Type
    User Defined
    Bounded
    Y
    Sort Order
    3
    Sort Method
    Ascending
  8. Because Quantity has a user-defined domain, create its domain manually by adding records to the Domains list as follows:
    1. Add a record to the Domains list and complete the necessary fields, as described in the following table:
      Field
      Value
      Sequence
      1
      Domain
      10
    2. Add another record to the Domains list and complete the necessary fields, as described in the following table:
      Field
      Value
      Sequence
      2
      Domain
      15
    3. Add another record to the Domains list and complete the necessary fields, as described in the following table:
      Field
      Value
      Sequence
      3
      Domain
      20
Adding Pricing Conditions
After you have set up the dimensions of the attribute adjustment, you can add conditions. The Conditions list has a column for each of the dimensions that you created.
In this example, you add the Conditions records manually instead of using the Generate Rules button.
To add pricing conditions
  1. Click the Conditions view tab.
  2. Add a record to the Conditions list and complete the necessary fields, as described in the following table:
    Field
    Value
    Sequence
    1
    Transmission
    Manual
    Act Type [=]
    Commercial
    Quantity [<]
    20
    Adjustment Type
    Price Override
    Adjustment Amount
    18,000
  3. Add a second record to the Conditions list and complete the necessary fields, as described in the following table:
    Field
    Value
    Sequence
    2
    Transmission
    Manual
    Act Type [=]
    Customer
    Quantity [<]
    15
    Adjustment Type
    % Markup
    Adjustment Amount
    10
  4. Add a third record to the Conditions list and complete the necessary fields, as described in the following table.
    Field
    Value
    Sequence
    3
    Transmission
    Automatic
    Act Type [=]
    Partner
    Quantity [<]
    10
    Adjustment Type
    % Discount
    Adjustment Amount
    10
Associating the Attribute Adjustment with a Product and Price List
After you have completed setting up the attribute adjustments, you must associate them with a product on a price list to make them effective. These conditions apply to the product named Van and to the price list named Americas Price List.
To associate the attribute adjustment with a product and price list
  1. Navigate to the Administration - Pricing screen, then Price Lists view.
  2. In the Price Lists list, select the record for the price list named Americas Price List.
  3. Click the Price List Line Items view tab.
  4. In the Price List Line Items list, find the record for the product named Van and in the Attribute Adjustment field, select Horizon Autos.
Testing the Attribute Adjustments
You can test the attribute adjustments for three different account types. This example assumes that you have created the following accounts:
  • ABC. Account Type = Customer.
  • XYZ. Account Type = Commercial.
  • 123. Account Type = Partner.
To test the attribute adjustments
  1. In the Quotes screen, create a new quote with price list Americas Price List and account ABC (Account Type = Customer).
  2. Add the product Van as a line item of the quote.
  3. Set the attribute Transmission to Manual as follows:
    1. Click Customize to launch Configurator.
    2. In Configurator, set the attribute Transmission to Manual.
    3. Click Done to exit from Configurator.
  4. For the quantity of the product Van, enter 16.
    The net price of the product Van is marked up by 10%.
  5. Click the Net Price field to display the pricing waterfall, to view this adjustment.
  6. Test the second attribute adjustment as follows:
    1. In the Quote, change the account to XYZ (Account Type = Commercial).
    2. In the line item, change the product quantity to 21.
      The net price of the product Van is $18,000.
  7. Test the third attribute adjustment as follows:
    1. In the Quote, change the account to 123 (Account Type = Partner).
    2. Click Customize and use Configurator to change the value of the attribute Transmission to Automatic.
    3. In the line item, change the product quantity to 11.
      The net price of the product Van is discounted by 10%.
Siebel Pricing Administration Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
