Siebel Pricing Administration Guide > Creating Attribute Adjustments > How the Pricing Procedure Uses Attribute AdjustmentsAfter an attribute adjustment is set up, the pricing procedure must perform a lookup against it in the pricing procedure so that adjustments can be applied at run time. For more information about the pricing procedure, see Pricing Procedures and Workflow References. The pricing procedure does this lookup using the Attribute Adjustment step, which invokes the Dynamic Lookup Transform. For more information about the Dynamic Lookup Transform, see Siebel Order Management Infrastructure Guide. |
Siebel Pricing Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
