Siebel Pricing Administration Guide > Creating Attribute Adjustments > Variable Maps in Attribute Adjustments > Using the Variable Maps View to Set Up Variable Maps for Pricing AdjustmentsUse the following procedure to set up variable maps for pricing adjustments by overwriting the variable maps in the Variable Map view. To set up variable maps for pricing adjustments using the Variable Maps view
The first approach is a global level change, and any new attribute adjustment table created after the server is restarted uses the new variable maps. The second approach is a local level change, and only the attribute adjustment that is modified uses the new variable maps. |
| Siebel Pricing Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
