Siebel Pricing Administration Guide > Pricing in the Run-Time Application > Spread Discount Pricing > Displaying a Warning if the Exact Discount Cannot Be SpreadIn some cases, the spread discount algorithm might not be able to spread exact total discount over the line items. In this case, it adjusts the total so it can be spread over the line items. There are two reasons why it might be impossible to spread the discount:
Maximum or minimum prices. For example, the products that the discount is applied to might have minimum prices that are so high that it is impossible to apply the entire discount to them. By default, the Siebel application does not display a message telling the user that the total has been adjusted. You can set up the application to display an error message if the total is adjusted.
The user can either accept the adjustment or cancel it and change the records to make it possible to spread the exact discount. |
| Siebel Pricing Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
