Siebel Pricing Administration Guide > Creating Product Promotions > Managing Versions of Product PromotionsYou manage versions of product promotions using the Product Promotions, Versions view. Managing versions of product promotions is not the same as managing versions of customizable products and product classes. Versions are mainly used to schedule product promotions with different effective dates. NOTE: Apart from the effective date fields, changes to the header of the product promotion, the More Info view, and the other views are not versioned. These changes take effect when the user selects Refresh Cache from the menu of the Promotion Header form, or when the user logs out and logs in again. Creating Product Promotion Versions with Different Effective DatesIf you are running a product promotion now and you want to run the same promotion a second time later in the year, then you can do this by creating promotion versions with different effective dates. For example, if you are running a promotion during the month of April, 2005, and you want to run the same promotion again during the month of June, 2005, then complete the steps in the following procedure. To create product promotion versions with different effective dates
| Siebel Pricing Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
