Siebel Pricing Administration Guide > Siebel Pricer Technical Reference >
Modifying Signals from Basic Pricing Procedure to Dynamic Pricing Procedure
The Siebel Business Application executes the Basic Pricing Procedure. In order to leverage the Dynamic Pricing Procedure, you need to obtain a Dynamic Pricer license and either:
- Automatically enable the Dynamic Pricing Procedure for all signals, as described in Step 2b of Switching from Basic to Dynamic Pricing Procedure.
- Or, manually modify several signal definitions as detailed in the following topics:
NOTE: If you automatically enable the Dynamic Pricing Procedure for all signals as described in Step 2b of Switching from Basic to Dynamic Pricing Procedure, then you do not need to make any changes to the signal definitions, and can ignore the following tasks:
