Siebel Product Administration Guide > Siebel Configurator Rule Assembly Language >
Why Use Rule Assembly Language?
Rule Assembly Language (RAL) is intended for those users who are more comfortable working in a programming environment rather than using templates. Those with experience using this language in previous releases can continue to use it in this release. In many cases, a combination of RAL and constraint templates can be effectively employed as follows.
- Use the existing templates to create basic configuration constraints.
- Create specialized templates and use them to create constraints to handle configuration areas that are similar.
- Use RAL to create highly complex or unusual constraints not easily handled by templates.
