Siebel Product Administration Guide > Siebel Configurator API Reference > Instance APIs for the Complex Object Manager >
GetAttribute Method
This method retrieves the value of an attribute. Input Arguments
- ObjId. The unique identifier of the complex object root.
- RootId. The unique identifier of the complex object root.
- (Optional) Version. Version arguments are used only when testing a customizable product version that is different from the currently released version.
- Path. The path of the item where you are retrieving an attribute.
- Name. The attribute name.
Output Arguments
The value is returned as a property of the output property set, as follows: <Output Value="value">
</Output>
