Siebel Product Administration Guide > Siebel Configurator API Reference > Instance APIs for the Complex Object Manager >
GetPossibleValues Method
This method retrieves selectable values from the configuration engine for an attribute. Input Arguments
- ObjId. The unique identifier of the complex object root (for example, Quote ID).
- RootId. The unique identifier of the complex object root (for example, Quote Line Item row id).
- (Optional) Version. Version arguments are used only when testing a customizable product version that is different from the currently released version.
- IntObjName. The name of the integration object.
- Path. The Integration ID of the port to which this attribute is attached.
- XA Id. The ID of the attribute for which the values need to be determined.
Output Arguments
The property set returned will have the possible values as the property names, as follows: < [PossibleValue1]="Val1" [PossibleValue2]="Val2"/>
