Siebel Product Administration Guide > Designing Products with Components > About Managing the Structure of Products with Components >
Editing a Relationship Definition
You can only edit the current work space of a product with components. You cannot edit a version that has already been released. All the fields in a relationship definition can be edited except the relationship name. Changes are not propagated to other parts of the product with components. To edit a relationship definition
- Navigate to the Administration - Product screen, then the Product Definitions view.
- In the Products list, select and lock the desired product with components.
- In the Versions list, click the Work Space version.
- In the Explorer applet, select the desired relationship.
- Edit the fields in the Structure record as desired.
- Revise configuration rules, resource definitions, link definitions, and scripts as needed to reflect the changes.
