Siebel Product Administration Guide > Designing Products with Components >
Creating a Report on a Product's Structure
You can request a report that lists all the relationships in a product with components as well as the contents of each relationship. You can request the report once, or schedule the report to run at scheduled times. The report title is Product Relationship Report. This report must be enabled on the report server before performing the following procedure. To create a report on a product's structure
- Remove the product with components from all existing quotes.
- Navigate to the Administration - Product screen, then the Product Definitions view.
- In the Products list, select and lock the desired product with components.
- In the Versions list, click the desired version.
- Click the Reports icon at the top of the screen to produce or schedule the report.
