Siebel Product Administration Guide > Multilingual Translations for Product Data >
Translating UI Property Values
Use this procedure to translate the value of a UI Property. The property type must be type String. To translate a UI property value
- Navigate to the Administration - Product screen, then the Product Definitions view.
- In the Products list, select and lock the desired customizable product.
- In the Versions list, click the Work Space version.
- Click the Properties view tab.
- Select the UI property you want to translate.
- From the Customizable Product menu, choose Translate UI Property.
A dialog box appears that displays the relationship name translations you have already created.
- In the dialog box, add a new record and complete the necessary fields, described in the following table.
Language |
Displays the name of the language after you select the code. |
Code |
Select a language code. |
Description |
Enter the translation of the description. |
