Siebel Product Administration Guide > Smart Part Numbers for Products with Attributes > Process of Creating Predefined Smart Part Numbers >
Creating a Part Number Generation Record
First, create a part number generation record. This record names the part number generation method and specifies whether the method is dynamic or predefined. This task is a step in Process of Creating Predefined Smart Part Numbers.
- Navigate to the Administration - Products screen, then the Product Classes view.
- In the Product Classes list, select the desired product class.
- Click the link in the Smart Part Number field.
- In the Part Number Definitions list, add a new record and complete the necessary fields, described in the following table.
Name |
Enter a name for the part number generation method. |
Type |
Select Predefined. |
