Siebel Product Administration Guide > Testing Products and Using Workspace Projects >
Working with the Scenario XML File
When you verify a scenario, then you can export that scenario as an XML file. The XML file contains the property set for that scenario, with all the properties that define the quote, order, asset, or agreement. After the XML file has been saved, you can use any text editor to edit the property set in the XML file rather than changing the definition in the Quotes, Orders, or Agreements screen. Then you can import the XML file into the application to update the scenario with the changes you made in the XML file. To export a scenario to an XML file
- Navigate to the Administration - Product screen, then the Workspace Projects view.
- In the Workspace Projects list, select the workspace for this scenario test.
- Click the Scenarios view tab.
- In the link bar of the Scenarios view, click either Test Quotes, Test Service Orders, Test Sales Orders, or Test Agreements.
- In the Scenarios list, select a test quotes, test service order, test sales order, or test agreement.
- From the menu in the Scenarios view, select Manage Scenario.
- In the Manage Scenario dialog box, click Export Scenario.
- In the File Download dialog box, click Save.
- In the Save As dialog box, specify the file name and directory and click OK.
To import a scenario from an XML file
- In the Manage Scenario dialog box, click Browse, and use the Choose File dialog box to select the XML file you want to import.
- In the Manage Scenario dialog box, click Import Scenario.
CAUTION: If there is a scenario with the same name and type, the scenario being imported from XML overwrites the existing scenario.
