Siebel Public Sector Guide > Managing Benefits Cases > Process of Managing Applications > Adding Attachments to ApplicationsAgents can add more detail to an application record by attaching relevant documents and other external media using the Application Attachments view of the Applications screen. The attachment can be in any format, such as a word-processing document. The attachments that citizens add on a self-service Web site also appear in the Application Attachments view of the Applications screen. You can add attachments to and delete attachments from applications with a Status field value of Saved, Submitted, or Rejected. You cannot add attachments to and delete attachments from applications with a Status field value of Cancelled or Processed. If you want to add an attachment after an application is processed, then add the attachment to the appropriate case record. For more information, see Adding Attachments to Cases. This task is a step in Process of Managing Applications. To add an attachment to an application
| Siebel Public Sector Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
