Siebel Public Sector Guide > Administering Siebel Public Sector > Process of Configuring Embedded Analytics >
Configuring Symbolic URLs
After configuring the host for the Analytics Server in Siebel Public Sector, the administrator configures the symbolic URLs for the paths to the appropriate reports in Oracle Business Intelligence. This task is a step in Process of Configuring Embedded Analytics. To configure symbolic URLs
- Navigate to the Administration - Integration screen, then the WI Symbolic URL List view.
- Select Symbolic URL Administration in the visibility filter.
- To set up the graph of the number of cases by status, complete the following steps:
- Select the PUBAnalyticsCase URL name.
- In the Symbolic URL Arguments list, in the Argument Value field for the Name field of Path, enter the path to the report for the graph of the number of cases by status.
The location of the report in your analytics setup determines this path. An example path follows:
/shared/Public Sector Analytics/Embedded/Cases By Status
- To set up the list of the top 10 suspects, complete the following steps:
- Select the PUBAnalyticsSuspect URL name.
- In the Symbolic URL Arguments list, in the Argument Value field for the Name field of Path, enter the path to the report for the list of the top 10 suspects.
/shared/Public Sector Analytics/Embedded/Top 10 Suspects by Case Type
