Siebel Public Sector Guide > Administering Siebel Public Sector >
Adding Images to the Siebel Public Sector Home Page
Administrators can change the image on the Siebel Public Sector home page using the Home Page Image Administration screen. For example, administrators can change the Warning Level indicator on the home page. After you publish the image, all users in the same organization can view the image. Different organizations can display different images. For optimal layout on the home page, the image must be no larger than 350 pixels wide and 175 pixels high. This task is a step in Roadmap for Administering Siebel Public Sector. To add an image to the home page Warning Level indicator
- Navigate to the Home Page Image Administration screen.
- In the Image list, create a new record, and complete the fields as appropriate.
The following table describes some of the fields.
File Name |
Select the file name or type the URL for the image. |
Publish |
Select this check box to display the image on the home page. Although you can add multiple images to the Image list, only this image appears on the home page. |
