Siebel Public Sector Guide > Managing Immigration Contacts >
Creating Visitor Stay Records
A user can create visitor stay records from the Stays view for an immigration contact. The Stays list shows all visitor stay records regardless of contact. Only administrators can delete visitor stay records using the Stays Administration view. For more information, see Administering Visitor Stay Records.
This task is a step in Process of Managing Immigration Contacts.
To create a visitor stay record
  1. Navigate to the Immigration Contacts Screen, then the Immigration Contacts view.
  2. Drill down on the Contact ID field of the contact record.
  3. Navigate to the Stays view.
  4. Create a new record, and complete the fields as appropriate.
    The following table describes some of the fields.
    Field
    Description
    Stay ID
    Displays an automatically generated number that uniquely identifies the visitor stay.
    Arrival Date
    Displays the date and time that you create the visitor stay record, but you can change this value.
    Port of Entry
    Displays the organization of the user who creates the visitor stay record, but you can change this value.
    Passport Number
    Select the passport number for the visitor stay. You can select only passports with a status of Active.
    Visa Number
    Select the visa number for the visitor stay. You can select only visas with a status of Active.
    Visa Type
    Displays the type of visa for the visa number that you select.
    Departure Date
    Select the scheduled date and time of departure for the visitor stay.
    Port of Departure
    Select the port of departure for the visitor.
    Arrival Vessel Number
    Type the number of the arrival vessel and additional information about the vessel.
    Departure Vessel Number
    Type the number of the departure vessel and additional information about the vessel.
    Days Overdue
    Displays the number of days that the visitor stay is overdue.
    Invalid Departure
    Displays a check in the check box for a prior stay record with no departure date if you create a new stay record for a contact that is associated with that prior stay record.
    The prior stay record becomes read-only, and any value in the days overdue field in that record is cleared.
Siebel Public Sector Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
