Siebel Public Sector Guide > Managing Immigration Contacts > Configuring the Immigration Contacts ScreenThe Immigration Contacts screen is based on the S_CONTACT table and the Contact business component and can replace for the Contacts screen for those organizations managing immigration processes. If you use both the Contacts screen and the Immigration Contacts screen in a deployment, then incorrect data is created in Siebel Public Sector. This task is a step in Process of Administering Immigration Contacts. To avoid conflicts between the Contacts screen and Immigration Contacts screen
Adding Views from the Contacts ScreenIn addition to the preconfigured set of views in the Immigration Contacts screen, you can copy views from the Contacts screen to augment the Immigration Contacts module. Some public sector organizations might want to track identities, credentials, and visitor stays for a contact. These organizations can relabel the screen as Contacts or Public Sector Contacts instead of the preconfigured label, Immigration Contacts. For more information about how to perform these tasks, see Using Siebel Tools and Configuring Siebel Business Applications. To add views from the Contacts screen to the Immigration Contacts screen |
| Siebel Public Sector Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
