Siebel Public Sector Guide > Managing Immigration Contacts >
Administering Credential Records
After a user creates a credential record, most record fields become read-only, and the user cannot delete the credential record. Only administrators can modify credential field values and delete credential records from the Credentials Administration view. This task is a step in Process of Administering Immigration Contacts. To administer a credential record
- Navigate to the Immigration Contacts screen, then the Credentials view.
- From the Credentials list, select Credentials Administration in the visibility filter.
- Select the credential record, and then modify the record, or delete the record.
