Siebel Public Sector Guide > Managing Investigative Cases > Process of Managing Incident Time >
Assigning Time to Incidents Using Calendars
Using the calendar, users can assign their time to an incident. If users want to use the calendar to assign the time of other users to an incident, then administrators must configure the Incident Calendar view to accommodate these time assignments. For more information, see Configuring Time Entry Views. Users can assign incident time by scheduling an activity and without scheduling an activity. Only the time that you assign to an incident by scheduling an activity appears on the calendar. For more information about administering and using the calendar, see Siebel Applications Administration Guide and Siebel Fundamentals. NOTE: The time that you assign to an incident is automatically associated with the appropriate time sheet. The appropriate time sheet has a time period that includes the date for the time assignment record, has the same owner as the time assignment record, and does not have a status of Submitted. If such a time sheet does not exist, then it is automatically created.
This task is a step in Process of Managing Incident Time. To assign time to an incident using a calendar
- Navigate to the Calendar screen, then the Incident Calendar view.
The Incident Time Items list shows your incident time items for the selected calendar date, and the Incidents list shows the incidents that are assigned to you regardless of status. At the bottom of the Incident Time Items list, the values in the Reported Hours field are totaled.
- Click the button for the daily, weekly, or monthly view to see the calendar format that you want.
The Incident Time Items list shows your incident time items for the selected date, week, or month.
- To assign your time to an incident by scheduling an activity, complete the following steps:
- In the calendar, create a new record for an activity that is associated with the incident.
- In the calendar form, enter a name for the activity in the Description field, select the activity type in the Type field, select the associated incident in the Incident field, and complete the other fields as appropriate.
When you select the associated incident, a new time record is added to the Incident Time Items list.
- (Optional) To assign time to multiple incidents, select additional incidents in the Incident field.
For each incident that you select, a new time record is added to the Incident Time Items list with a Reported Hours field value that corresponds to the Duration field value in the calendar form. You can change the Reported Hours field values for the records in the Incident Time Items list. If you change the date and duration in the calendar form, then the corresponding field values in the Incident Time Items list do not automatically change, but you can manually change these corresponding field values.
- In the Incident Time Items list, select the time type in the Type field.
If you change the date, incident, and reported hours in a record in the Incident Time Items list, then the corresponding field values for the scheduled activity in the calendar do not automatically change.
- Click Save This One to return to the calendar.
- To assign your time to an incident without scheduling an activity, create a new record in the Incident Time Items list.
For information about the fields in this view, see Assigning Time to Incidents Using Time Sheets.
