Siebel Remote and Replication Manager Administration Guide > Configuring the Remote Client > Controlling the Data That Siebel Remote Routes to Clients >
Modifying a Routing Model
If you use the Database Extensibility feature to create an extension table, then you can sometimes use the docking wizard in Siebel Tools to create a routing rule. You can use this wizard for a custom table that you have not yet placed in a dock object or for a custom extension column that you have not yet added to a predefined table. If you use this wizard to create a new rule, then to maintain optimum performance, it is recommended that you index the server database columns that the new rule affects. For help with modifying a routing model, see Getting Help from Oracle. For more information about the docking wizard, see Configuring Siebel Business Applications.
