| Siebel CRM Siebel Security Guide Siebel Innovation Pack 2015 E24814-01 |
![]() Previous |
![]() Next |
View PDF |
This topic outlines procedures for setting up divisions, organizations, positions, and responsibilities. For more information, see the following topics:
This topic describes how to set up divisions.
Navigate to the Administration - Group screen, then the Internal Divisions view.
The Internal Divisions view appears.
In the form, add a new record and complete the necessary fields.
Some fields are described in the following table.
| Field | Guideline |
| Parent Division | If this division is a subdivision, select the parent division. This allows a division to be associated with another division. |
| Organization Type | Indicates the type of organization, which controls where in the application a division will appear for selection purposes.
For example, divisions with Organization Type set to Service appear for selection in the Group field on the Service screen, Service Requests view. |
| Organization Flag | When selected, indicates that the division is also an organization. The division is copied into the Organization view. |
This topic describes how to set up organizations.
Navigate to the Administration - Group screen, then the Organizations view.
The Organizations view appears.
| Field | Guideline |
| Parent Organization | If this organization is a suborganization, select the parent organization. This allows an organization to be associated with another organization. |
| Partner Flag | Used for Siebel Partner Relationship Manager. This is a read-only check box. When the box is checked, this indicates that the organization represents an external enterprise that is a partner of your company.
Note: Partners are registered and promoted to organizations using the Approved Partners view in the Administration - Partner screen, as described in Developing and Deploying Siebel Business Applications. |
This topic describes how to set up positions.
Navigate to the Administration - Group screen, then the Positions view.
The Positions view appears.
Note: Most fields in the form are filled in automatically from the Employee record of the active employee. If you have not set up employees, you can associate them with positions later. |
| Field | Guideline |
| End Date | Last day for the currently associated employee to be associated with this position. |
| Last Name | Select one or more employees to occupy the position. In the Assigned Employees dialog box, select the Primary field for the employee whom you want to make primary for this position. |
| Parent Position | If this position is a subposition, select the parent position. This allows a position to be associated with another position. |
| Position Type | Type of position. This field is informational and has no impact on visibility. |
| Territory | This field is a read-only multi-value group. You are not able to enter a value manually. For use by Siebel Assignment Manager. |
This topic describes how to set up responsibilities and add views and users.
To define a responsibility and add views and users
Navigate to the Administration - Application screen, then the Responsibilities view.
The Responsibilities view appears.
Note: By default, the Responsibilities view shows all responsibilities, regardless of organization. However, you might want to configure new views in Siebel Tools that restrict the visibility to responsibilities. For more information on configuring views, see Configuring Siebel Business Applications. |
In the Responsibilities list, add a new record and enter a name and description for the responsibility.
In the Organization field, select an organization for the responsibility.
To add views, do the following:
In the Views list, add a new record.
Select the appropriate views in the Add Views dialog box and click OK.
When you add a view, set the flag Read Only View if users with this responsibility only require read access to the view.
Note: You can also delete views from the Views list. |
To add users, do the following:
In the Users list, add a new record.
Select the appropriate users in the Add Users dialog box and click OK.
Note: You can also delete employees from the Users list. |
Related Topic
