| Siebel CRM Siebel Security Guide Siebel Innovation Pack 2015 E24814-01 |
![]() Previous |
![]() Next |
View PDF |
A business component's view modes determine the allowable access control mechanisms that can be applied to the business component in any view. When a view is based on a particular business component, the view must use one of the view modes specified for the business component. For example, the Account business component can only be used in Organization view mode or Sales Rep view mode.
Each view mode also determines how data is associated with a user to determine whether the user gets access. For example, a business component that allows personal access control might connect the data to the person by comparing the data's Owner Id field to the person's user ID. Another business component might apply personal access control through the data's Created by field.
Note: If a business component does not have view modes listed, then there is no access control associated with the business component in views that are based on that business component. |
You use Siebel Tools to work with properties of business components. For information about working with business components, see Configuring Siebel Business Applications.
The following procedure describes how to view a business component's view mode in Siebel Tools.
To view a business component's view mode and visibility fields
Launch Siebel Tools.
In the Object Explorer, expand the Business Component object type.
The Business Component subtree appears.
Click the BusComp View Mode icon.
The Business Components list and its BusComp View Modes detail list appear.
In the Business Components list, select a business component for which there are records in the BusComp View Modes list.
A record in the BusComp View Modes list represents one view mode the business component can assume.
Table 9-4 shows the fields in the BusComp View Modes list that determine the allowable visibility for a business component.
Table 9-4 Fields that Determine Visibility for Business Components
