| Siebel CRM Siebel Security Guide Siebel Innovation Pack 2015 E24814-01 |
![]() Previous |
![]() Next |
View PDF |
Table 1-1 lists the changes in this revision of the documentation to support this release of the software.
Note: Siebel Innovation Pack 2015 is a continuation of the Siebel 8.1/8.2 release. |
Table 1-1 New Product Features in Siebel Security Guide, Siebel Innovation Pack 2015
| Topic | Description |
"About Using Transport Layer Security with Siebel CRM" |
New topic. It is strongly recommended that you use the Transport layer Security (TLS) protocol for Siebel CRM environments with security requirements. |
Various topics |
Modified topics. The use of Secure Socket Layer (SSL) v3.0 communications encryption is no longer supported for Siebel CRM environments with security requirements and has been removed from the guide. Implement Transport Layer Security (TLS) protocol instead of SSL. |
"Changing AnonPassword When SADMIN is set to Anonymous User" |
New topic. If you set SADMIN to AnonUserName in the eapps.cfg file, then you must also change the password for the anonymous user (AnonPassword) in eapps.cfg. |
Modified topics. You can install Oracle LDAP Client software either using or without using the Siebel Enterprise Server installer.
"Installing Oracle LDAP Client Software Using Siebel Enterprise Server Installer" |
New topic. Describes how to install the Oracle LDAP Client from the Siebel Enterprise Server Installer. |
"Web Single Sign-On and Silent Login" |
New topic. When Siebel and an external application are both configured with the same SSO credentials, then silent login is supported. |
