Siebel CTI Administration Guide > Administering Siebel Communications Server > Siebel Server Requirements for Siebel Communications Server > Using Siebel Server Load Balancing with Siebel Communications ServerIf you use Siebel Server load balancing to implement load balancing among multiple instances of Siebel Server, then, for each Siebel Server participating in load balancing, you must enable the Communications Management component group, as noted, and enable or start any applicable Communications Server components. If you are also using Communications Session Manager, then you must set the Enable Communication parameter to True for each Application Object Manager instance. For more information about enabling communications, see Enabling Session Communications. NOTE: Siebel Server load balancing does not load balance requests for Siebel Communications Server. Rather, in this case the Application Object Manager from which a Communications Server request is made is load-balanced and requires that the necessary Communications Server components be enabled and running. For more information about installing and configuring Siebel Server and Siebel Server load balancing, see the Siebel Installation Guide for the operating system you are using and Siebel System Administration Guide. |
| Siebel CTI Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
