Siebel CTI Administration Guide > Configuring Communications Drivers and Profiles > Configuring Communications Drivers and Profiles > Setting Driver Parameter Default ValuesYou can specify a new default value for a driver parameter. You can modify any default value in a profile. For certain parameters, you typically provide values through profile parameter overrides. If you expect that a particular parameter value applies to all or most of the profiles that you create, that is, you do not expect to override the value, then specify this value as the default driver parameter value. Doing so saves you time when you create profiles, because you might not have to define an override for this driver parameter. For more information about configuring driver parameters for email servers, see Siebel Email Administration Guide. To specify a driver parameter default value
| Siebel CTI Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
