Siebel CTI Administration Guide > Configuring Communications Drivers and Profiles > Configuring Communications Drivers and Profiles > Specifying Parameter Override Values for ProfilesThis topic describes specifying any new values to override the default values of driver parameters. You must do this for required parameters that are not defined for the driver, or for parameters for which the driver parameter default value is not appropriate for each profile. For more information about driver parameters, see Specifying Driver Parameter Values. To specify parameter override values for a profile
Siebel CTI Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
