Siebel CTI Administration Guide > Configuring Siebel CTI > Creating or Modifying a Communications Configuration > Specifying Parameters for a Communications ConfigurationUse the All Configurations view to specify parameter values for a communications configuration. Configuration parameters are in effect for all agents who are included in the configuration for the contact center. Certain elements associated with a communications configuration also have parameters that affect the overall function of the configuration. Such elements include communications drivers and profiles, commands, and events. The communications configurations provided with Siebel Business Applications include configuration parameters and default values. Parameters for Communications Configurations lists these configuration parameters and provides applicable default values, which are in effect for each parameter if it is not defined. Some parameters must be included, while others are optional. This topic is part of Creating or Modifying a Communications Configuration. To specify configuration parameters
| Siebel CTI Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
