Siebel CTI Administration Guide > Configuring User Interface Elements > Modifying the Communications Toolbar >
Moving, Adding, or Removing a Toolbar Button
You can customize the communications toolbar to add a new toolbar button or to remove an existing button. You can:
  • Move a toolbar button or other control on the communications toolbar
    You can move a toolbar control, in relation to other controls, by modifying the value of the Position field for the applicable toolbar item in Siebel Tools.
  • Remove a toolbar button or other control from the communications toolbar
    You can prevent a control from appearing in the communications toolbar by setting the Inactive flag to True for the applicable toolbar item in Siebel Tools.
  • Add a new button to the communications toolbar
    If you add a new toolbar button to the communications toolbar, then you must also add, or reuse, all associated object definitions in Siebel Tools and image files. The scope of what you have to do depends on the purpose of the new button.
Siebel CTI Administration Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
