Siebel CTI Administration Guide > Configuring User Interface Elements > Configuring Communications Menu Commands > Communications Submenu and Applet-Level MenuWhen communications are enabled for a user, the Communications submenu is displayed in the Tools application-level menu. The Communications submenu is configured using commands defined in the communications configuration. The name and position of Communications as an item in the Tools application-level menu is determined in Siebel Tools by the Tools - Communications menu item definition. Like the communications toolbar, the exact content of the Communications submenu varies according to the communications configuration that you are using. All the sample communications configurations provided with Siebel Business Applications contain definitions to configure the Communications submenu. The applet-level menu, which is accessed at the top of each applet, below the applet name, is generally available in the Siebel client. When session communications are enabled, communications-related items are added to it, according to the commands defined for the communications configuration. |
| Siebel CTI Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
