Siebel CTI Administration Guide > Configuring User Interface Elements > Configuring Communications List of Values Types > List of Values Type for Channel TypeThis topic identifies the List of Values type for specifying the channel type for communications drivers. If the available communications channel types do not meet your needs for your communications drivers, and you want to add or modify channels, then you must add or modify records to include the values that you require. The applicable List of Values type is COMM_MEDIA_TYPE. The Parent LIC value is set to COMM for values to be displayed only in the Channel Type field in the Communications Drivers applet (in the Communications Drivers and Profiles view in the Administration - Communications screen). For more information about defining drivers, see Configuring Communications Drivers and Profiles. |
Siebel CTI Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
