Siebel CTI Administration Guide > Configuring Events and Commands > About Events and Commands > Communications Definition Data in the DatabaseThe Siebel database contains configuration data that helps determine how your communications system is integrated with your Siebel application. Among other functions, the communications configuration data:
NOTE: The events recognized by the communications driver and the commands supported by the driver are a subset of those supported by the communications system, such as your CTI middleware. For information about the events, commands, and parameters supported by the Virtual CTI driver, see Using the Virtual CTI Driver. To customize the communications configuration, you must understand your call center's workflow model, as well as the key business objects for your Siebel application. You customize communications features by editing or entering data in a series of views in the Administration - Communications screen, as described in Views for Communications Administration. |
| Siebel CTI Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
