Siebel CTI Administration Guide > Overview of Siebel CTI and Related Products > About Communications Configuration DataThe Administration - Communications screen allows administrators to configure several kinds of communications data. Sample communications configuration data is provided in the Siebel database. You can modify the preconfigured (out of the box) data, or create new data, to customize Siebel Communications Server and the Siebel Business Applications to support the communications channels that you use and to support your business processes. You can also find the sample communications configuration data in the Siebel Sample Database. |
Siebel CTI Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
