Siebel Installation Guide for UNIX > Additional Postinstallation and Configuration Tasks > Additional Tasks for the Siebel Web Server Extension and the Web Server > Configuring the Web ServerThis topic describes steps for configuring the Web server for use with the SWSE. Some other documented postinstallation tasks also involve Web server configuration. Additional Web server configuration tasks are described in Installing the Web Server. For version information for supported Web servers and the operating systems they run on (where you also install SWSE), see the Certifications tab on My Oracle Support. For Apache-based Web servers, to configure the Web server for use with the SWSE, you must edit the Web server configuration file httpd.conf. For more information about the location of this file, see Installing the Web Server. This topic is part of Additional Tasks for the Siebel Web Server Extension and the Web Server. Use the following guidelines for setting parameters in the httpd.conf file when using Apache-based Web servers with Siebel Business Applications. Requirements for an Apache-Based Web ServerUse the following settings for configuring an Apache-based Web server. Some adjustments to these values might be needed, as outlined in article 871352.1 (Article ID) on My Oracle Support.
Recommendations for an Apache-Based Web ServerThe following are recommended settings for configuring an Apache-based Web server:
Optional Settings for an Apache-Based Web ServerIf you are not using the CGI functionality of your Apache-based Web server, then you can optionally add comment characters and disable the line that loads the CGI module. Doing this makes tracking Web server processes simpler because there is always one child process. |
| Siebel Installation Guide for UNIX | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
