Siebel Installation Guide for UNIX > Additional Postinstallation and Configuration Tasks > Additional Tasks for the Siebel Web Server Extension and the Web Server > Configuring Oracle iPlanet Web Server to Accept the SWSEFor the Oracle iPlanet Web Server running on Oracle Solaris, you must configure the Web server to accept the changes that the SWSE Configuration Wizard makes to the Web server configuration files when you configure the SWSE. CAUTION: If you do not configure the Web server as described here, then changes that you might make in the future to the Web server configuration will overwrite the changes made by the SWSE Configuration Wizard. This topic is part of Additional Tasks for the Siebel Web Server Extension and the Web Server. To configure Oracle iPlanet Web Server to accept changes made by SWSE
Oracle iPlanet Web Server References to the eapps.cfg FileWhen you configure the Siebel Web Server Extension, the SWSE Configuration Wizard adds a reference to the Oracle iPlanet Web Server configuration file magnus.conf. This file specifies global settings of the Web server, such as server information, object file configuration, DNS lookup, ACL, and so on. A typical line the SWSE Configuration Wizard would add to magnus.conf might resemble the following example: Init fn="swe-init" config-file=" In this entry, SWSE_ROOT is the root directory where the SWSE is installed. |
| Siebel Installation Guide for UNIX | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
